XFI with XIM how to wire 2 step?
chasmat2316
Looking for info how to set up & wire a momentary button so I can foot brake to build boost. I had a Bailey 2 step that I took out when I converted over to XIM. I'm using xfi 2.05 with a caspars long xfi adapter
thanx for any info
Charlie
I use the Clutch input (A20) to control the T-brake. If you go into the help files they have some schematics for trans brake wiring.
AG.
ok thanx for the info, looks like I need a digital relay?
Relay is only really needed if you have an electric trans brake and want to use the trans creep feature. If your foot braking than just use pin A20 to trigger the 2-step.
AG.
AG.
ok great so pin a20 goes thru a momentary button to ground?
Yes, that should work, don't forget yo configure the 2-step in the rev limit menu
