Pittsburghkid
Displacement Replacement.
- Mar 22, 2009
wow learn somethin new every day. Was the grand prix seat brace the same as the gnx or like the after market tubular bolt in design?
SignUp Now!I have the old Poston's frame end to end bar and it doesnt clear my stacked intercooer.
I totally agree that this is all very much needed. This is a terrible problem in 68-72 a bodies..especially convertibles. I have a 71 GTO and pirated a set of jounce bars from some car. It made the most difference ever. If you look at the steering box/frame horn when its operated with car off, basically get someone to turn wheel left to right, you can actually see the frame horn move l/r from the force of it having to move steering gear linkage. Its amazing how soft the frame really is! This ive seen on the a bodies, so it should occur on G bodies too.
Oh yea, forgot to say, also the postons jounce bars didnt clear my ic. I think they sold GP factory part.
hello; I e-mailed SC&C with no reply and I'm going to give them a call today with the question if there brace definitely fits with the larger SLIC. Do you have the SC&C on your car with the PTE SLIC? I might go for it.The front frame horn brace (the Gran Prix brace that ties the jounce bars and front end of the frame) shown above won't work on a SLIC equipped car, but this one will. SC&C Heavy Duty Chassis Brace - Buick Grand National | Savitske Classic & Custom
Pitssburgkid,
That reminds me of the 18 wheeler cab grab bar some are saying works well. Anyway, i am interested , but need to have my car home to contemplate the fitment. I have a stacked IC, do you think your bar would work? thanks
I have most of the braces on my car. They all helped.
The rear seat and under frame brace the most. The underhood braces were a colossal PITA to install, as I had to remove a bunch of stuff to do it. Ive had the GNX #5 bushings for forever, maybe I'll get to install them at some point in the near future. I actually saw them installed for the first time on a real X two weeks ago.
As for the SC&C brace, it fits great. Kinda a pain to install but its worth it. It WILL NOT work with the 36mm F-Body swaybar! It will only work with a stock G-body swaybar or a aftermarket one for a G-body. Ask me how I know...
I think the brace will work with the PT&E SLIC itself, but the shroud may be another story. Im planning on going to a PTE IC, just haven't gotten to it yet. So I digress on that.
But the SC&C brace is a solid, well designed piece. If anyone has any question on the install, Ive done it. Its not too bad.
hello; Thanks for the info. as I've been waiting for a 36mm sway bar to come up but if what you say is true the search has ended. It does sound like the SC & C is a quality pc. not just a tube with crushed ends as decribed to me recently.
IBBY
hello; And to Dennis Kirban. I had made a suggestion on this site in the past on a new product. That product would be to redesign one brace (I think it was the left one looking at the front of the car) is not a major change but it should make the braces fit with a over sized SLIC. With my PT&E SLIC that brace will not fit. There are alot of people going for a new SLIC and it makes sense to me. People are coming up with ways to make it work but a optional brace to the ones made now would be a good way to go.
IBBY
My GN is stripped down so doing either seat brace would not be a issue but if i ended up doing the GNX type and welding it in i would want to do it now. It sounds like no one has ever really found any difference in the two though what about doing both or is that way overkill! I'm sure that would keep it tight!!!!!
Chris
