Zo6 MAF with IAC
spross86
Should be here today I want to use the built in IAC but can't find a caspers number on there site is anybody using this setup and where did you get the adapter.
Thanks ED
I thought we couldn't use that lead for the temp? I don't, I use the factory temp sender and yes you do need the caspers wire adapter for the LS7 maf to our 3 wire maf plug.
supposedly the sensor wont read as gospel on our system but the amount it will be off wont affect operation since the ecu only compensates for extreme cold or extreme heat
guys pushing alky and logging should really move the IAT sensor to the plenum
the 85mm MAF (Z06/truck/lotsa stuff) has an IAT that works fine.
the drop-in style MAF element has an IAT that has a much different calibration.
Bob
