its the same idea that red armstrong does to his xp pump but he epoxies his. still they dont flow as much as the aeromotive
How do you know? I linked a flow test that says it is very close. So I did more research and here I found that kenne bell says 1 volt at the pump is 10% so .5 volt is 5% ish.
The test I linked to is tested at 14 volts. The aero chart is 13.5. So I did the math:
The first figures are a modified 255 @ 14v, second row is 255 modified @ 13.5with my math, an third row is 340 aero trying to read there chart posted in this thread. The 340 looks like a walbro modified almost to a T!! Or a walbro with no pressure relief.
40psi @ 14v = 339 @ 13.5v = 322ish @13.5v = 340ish
50psi @ 14v= 331 @ 13.5v = 315ish @ 13.5v = 320ish
60 psi @ 14v= 309 @ 13.5v= 294ish @ 13.5v = 280ish
70psi @ 14v = 296 @ 13.5v = 281ish @ 13.5v = 260ish
80psi @ 14v= 277 @ 13.5v = 263ish @ 13.5v = 230ish
90psi @ 14v=259 @ 13.5 = 230ish @ 13.5v = 200ish
I want this to new pump to be the best. But I also don't want to buy a expensive walbro with no pressure relief. I hope this post is very wrong. But until someone flows one of these I am not sure. I really hope someone sends all 3 new pumps that have been talked about in this thread to kinsler to be flow tested. I would but I am poor.
