The power plate is not an issue of plus or minus.
Take your plenum off.. that power plate will have a film of oil on it from the PCV. If it was getting wet from the methanol.. there would be no oil on it. meaning that by the time the methanol is inside the motor.. it has already flashed with the incoming air.. so wherever the air goes.. so does the alky. Ther is no puddling.
Think of this.. methanol flashes at 70 degree's.. every PSI boost heats air 11 degree's.. so 20 PSI is 220 degree's above ambient coming out of the turbo.
You want my take.. here.. run both alky and race gas. whats the big deal.
