I'll be in the shop today.........
As far as flow charts, engineering data and other info, results tell all. In the 9 and 10 sec. cars from which I have obtained results, Cotton's, PS and even a V-2, have had similar results.
Thanks for finally answering my questions Nick, unfortunately, your answers which obviously are not a direct answer, tells me and everyone else nothing, other than cars run good with any IC....
I would just like to know about the results from your "testing", which I took as several IC being tested at the same time with the same car.... Now if that isn't the case, could you just tell us that? Also since you use 2 of the dimensions of an IC to determine size, why wouldn't you use the third dimension? I've never seen spec on IC cores listed by width and height, always WxHxDepth.....
I really don't care to be posting to this thread, but since I feel information is not accurate, I am left no choice but too..... If you are going to use my IC as an example test product, I have questions.... Nick, if you don't want to be more specific, thats ok, this is your playground, not mine..........
As for the PS IC, God bless you guys.......... I am in no way knocking anything you are doing, just want info related to mine supported. I looked at an engine bay this morning and just shook my head, thinking of the work involved to adapt it. I give you guys credit for your persistance and creativity. If it wasn't for all the trans line, AC lines, battery and other stuff, the average guy could do the IC install without too much trouble, just time. As for the tubing and bends, looks to be about the same amount of bends to accomplish the connections, just shorter tubes.
