Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
when it cuts out it stumble's and has irattic idle and just dies, its not like shutting the key off, When I did the iac reset I took the throttle body off and cleaned the IAC very good, couldnt get the rpms that low only like 800-900rpms, when i was done setting the perimeters in the tps it surged up and down for a minute then stayed at a constant idle. Ran great with the rpms at 800-900 rpms, until i got home then stumbled and died. I will check to see if the grounds under the ac comp are clean and tight. Also I tested my old module , it failed, And got a module off of Esasky from this forum and just put it on after I got it assuming that one worked, took it off today got it tested and that also failed. I have a 86-87 that passed so I will order a caspers adapter and plate to compete the conversion to see if that helps, For the conversion is the 86-87 module, coil, ecm, caspers adapter and plate all that is needed or do I have to upgrade the MAF to the LT1 with a translator aswell??? thanks man much appreciated
How were the modules tested?
You need to verify if the car looses spark when it stalls . . . . . . it sounds like you have a vacuum leak as well.
With a scantool you would be able to see the idle BLM change and probably max out.
Leave the MAF for now and replace one thing at a time.
You would need scantool to determine the condition of the MAF.
