Help with my 84 hot air GN
When you adjust the idle adjustment screw
It's proper name is minimum air adjustment screw according to turbo tweak.
You are supposed to adjust it for IAC counts of 10-40. If after doing this, if the idle is high, I believe it indicates a vacuum leak.
With the proper IAC count, the ECM is suppose to control the idle at the proper level.
I've been researching adding an 86-87 ECM to my 85 hot air car. I read that the 85 does not have a MAT, (air temperature) sensor.
If you install an 86-87 ecm, you will get a SES light. It's a fair bit of work to install the MAT but I think you have to do it and
it also says you need the 86-87 MAF. I'd say you have to get these resolved.
Read about it here:
http://www.gnttype.org/techarea/ecmsensors/8487ecm.html
