hodgeofflo
- Nov 8, 2002
I hooked my 87 Turbo T to a scanner, and I am getting 10 degrees of retard at max boost of 15 lbs. At the suggestion of my mechanic, I got a high perf fuel pump, adj fuel press regulator, and put a new fuel filter on, but that did not help. The fuel pressure is set correctly, and it is increasing 1 lb of pressure for each lb of boost. I have also done the full "spring cleaning tuneup", including all filters, plugs, wires, oil, tranny fluid, etc.
I just want to get the car to good stock condition. I don't want to add alky, and would rather not change the chip, both of which are my mechanics next suggestions.
Any suggestions on what else I can do?
