10 sec longblock
mturbo87
Mike
30 over trws
stock crank and rods
206/206 weber roller cam set up
stock heads,with mannely valves (flowed 209)
cometic headgaskets
block decked, and heads/block were lapped
half inch head bolts
intacke port matched
total seal rings
all bearings are standard
stock rockers with crome molly shaft
Car went 10.59 @129 with 165 60 ft in a 3600 lbs gn. Had 55lbs injectors with a 62 mil turbo. Motor has 400 miles on it. Did some extra work on machine work to hold these heads on and it was worth it. Asking 5,000.00
