I had this car for sale in the fall of last year and had some serious buyers, but I changed jobs at that time and had to do quite a bit of traveling at first so I had to put the car on the back burner until I had more time to deal with it. I have added a few items since it was last for sale such as a Full Throttle 4" MAF pipe with built in MAF, MAF Translator, and a Alky Control Dual Nozzle Alky system. I also added new wheels. The car is a 70K mile car that has been well cared for its entire life. It is 100% rust free and still has its original paint. I bought the car 2 years ago with 69K miles and a bad motor. The car was pretty close to stock then with just a few bolt-ons and had never been faster than low 13's. The previous owner installed a set of injectors that he thought were 50's but turned out to be 36's and the 36's combined with a chip for 50's caused detonation and is the reason the motor was hurt when I bought it. I had the motor built by an experienced turbo Buick engine builder and the parts used in the build are listed below. The motor has 2K miles on it and transmission has 1.5K miles on it. I went thru the rear also and it has 1K miles on it. It drives like a stocker and could be driven anywhere. I drove it 600 miles in 3 days last year on the Hot Power Tour with no problems at all. The car went 10.76 @ 126 with pump gas/alky on drag radials. When the car went 10.76 it still had the stock MAF and a Devilsown alky system on it. The Deveilsown system was running flat out and worked great but I upgraded to Razor's dual nozzle alky set up so I could crank up the boost a little more. I think the car will run 10.40's fairly easily with just a little more seat time and a little better 60' time. The 10.76 was with only a 1.69 60'. I want $15,900 for the car. Please no low ball offers. I would like to sell it to fund other projects but if I can't get what I want for it I will gladly keep it
109 block with center billet mains
4340 forged crank(internal balance)
JW SFI flywheel
Speed Pro forged pistons
ARP fasteners(mains, rod bolts, and head studs)
208/208 Full Throttle cam
Comp duble roller chain
Ported irons
ATR extrenal gate Stainless DP
Tial 38mm wastegate
Motoron 60's
Accufab billet regulator
Alky Control dual nozzle progressive alky system
TT alky chip and Red's 93 and 107
4" cold air with filter relocated in front of core support
MAF Translator
PTE front mount(custom stainless piping)
PT-70 P-trim turbo with .63 housing(spools great)
Dual 3" aluminized exhaust, exits in stock location
built 200r4 w/ billet hard parts, red clutches & band(from CK Performance)
Cast aluminum deep trans pan with 4l60 filter
PI Vigilante multi-disc Billet faced converter 3400
Moser axles and Auburn posi in stock 8.5 rear
Walbro 340
F-body aluminum radiator
Aluminum rear drums
aluminum bumper brackets
6 point Chromoly roll bar by www.tydoracecars.com (The roll bar was built so that the back seat is still completely useable)
JW SFI flywheel
Ported irons
Tial 38mm wastegate
Motoron 60's
MAF Translator
Walbro 340
Aluminum rear drums
