100% standard block
USMC_Turbo6
I need a standard 109 block that's 100% true or only 10 over that will not need to be touched. I am trying to keep from buying new piston and use the ones I have. Will trade you my 30 over block an some cash for one.
Hey Leatherneck, where are u located?. I have a stock bore 85 block, still has the honing marks. I just pulled out of wifes gn doing 87 set up.
If you are going to BG I may be able to send a 140 block that way for an exchange with you.;) You can see a very slight ridge in it but I can't catch a fingernail on the ridge at all.
Block has to be out of a 86/87.
Sent from my SPH-L710 using TurboBuick Mobile mobile app
