109 Motor Wanted
BUFORD93
I am looking for a 109 short block it can either be built already or a rebuildable motor. I am in Georgia so the closer the better.Let me know what you have.
109 motor
I have a 109 motor that is at the machine shop as we speek. I am just freshening it up to sell because I put a stage II motor in my car. The block has the 2 center billet mains and pistons have been ceramic coated on top and teflon coated on skirts. This is a complete long block with ported heads and 1.77" int valves. Has 210/205 hyd flat tappet cam. All fresh and ready to go in about 1 week. Let me know if you are interested.
I have a 109 short block 45k miles only mods are 210-205 flat tappet,gm lifters double roller chain set for $800 short block includes flex plate,balancer,crank sensor,crank and water pump pulleys,cam sensor,motor mounts,turbo feed and drain lines,waterpump,knock sensor I'm located west of Atlanta and will deliver thanks,jeff
