109 perf engine value?
seeya v6
Hello, I have a 109 long block with 0 miles on it, Iam considering selling it but not sure what its worth?
109 block (O miles wrapped in plastic)
#2+3 steel main caps
stock crank .010+.020
stock rods
J+E .040 pistons
212\212 hyd roller comp cam + lifters
solid rocker shafts stock rockers
iron heads with 1.77 intake valves and port work
High vol oil pump
ARP rodbolts, main studs, and head studs
new bearings and rings
I made 500rwhp with a TE45a two years ago then I built a 4.1 stroker.
I had the motor freshend up for another car but never used it,my question is what do you think it's worth?
