109 Short block built by RPE Performance
TURBOGTA1
Life is Sweet !!!
109 Short block built by RPE Performance.
020 over block, J.E Pistons & Precision pins,
Eagle forged crank, stock rods.
RJC girdle, scraper, and 7.5qt oil pan.
All ARP hardware.
Billet custom hydraulic roller cam by Comp & Lifters.
DLS thrust assy.
New GM front cover modified.
BHJ sfi balancer—J.W flywheel.
Rotating assembly fully balanced.
This engine is complete and currently running in a car, that I would be more than happy to demo. You get a complete short block including everything listed above, rite to the filter ready to be installed with your top end & accessories, and drive/race in a day!!
This short block with GN1’s and a 70 turbo made just over 600hp to the wheels on a very fat tune. Full weight GN with a sh*t launch went
10.53 @ 129.5mph with a crappy 1.62 60’ (again on a fat tune) with plenty more left. I have data logs, dyno-sheets and video of the car, as well as all receipts. Oil pressure hot, idling in gear after a nice drive is about 35psi. Motor has a few 10 sec passes, and about 1,800 miles, (mostly hi-way). Motor still looks like the pictures below. I've changed the oil at least 6 times since built. I built the motor to drive anywhere, and put down some good times at the track. This engine with a good top combo on a Trans brake will dip into the 9’s. Or just get in and cruise anywhere!! Looking for $5,500. E-mail me direct at Turbogta@aol.com
TTT, Not looking for any trades.
Need to move the motor, so I can sell the rest of my Performance parts. Save a few thousand plus dollars, no hassle, and no long wait.
Will have it ready to go first weekend after deal is done.
He did a awesome job on the one he built for me-wouldnt hesitate using him again. good luck with your sale- great motor for the price!
Here are a few more pictures, including what it looks like under the hood today!! Going back to stock sale. Everything under the hood except the Alky will be for sale as soon as the short block is sold. Including GN1's, T&D's, intakes, turbo, exhaust, fuel system, the list goes on. Will sell as complete as someone wants.
I also have a 200r Trans rebuilt stage I, that can be test driven. Shifts beautiful.
Turbogta@aol.com
Mike
Killer deal for this motor-i have 6K into mine-exactly like this without the girdle and billet crank!
Cost me $8500 plus the block. How about a long block from intake to pan.
Complete short block as advertised, a set of Champion GN1 (new version)Cylinder heads that have the upgraded Bee-hive springs for hydraulic roller cam, (done by Champion)
T&D Rocker arm assy. Champion ported stock style intake, Manley Push rods, ARP head bolts, Cometic head gaskets with Champion valve covers. Everything is like new, and has little use. $7,500, (which would cost $12,500 to build) and a lot of work.
This motor is running right now, and can be test driven. I will pull it complete, and you can be on the road in a weekend.
