I removed the pistons from my 109 '87 block to check the rings, and I made a fatal error...............I mixed them up.
Did the factory put any mark on the pistons or rods to match which cylinder they came from? Please help.........a full balance will cost a fortune. Was a full rotating assembly (crank, rods, pistons and flex plate) balance even done at the factory????........or was only the crank balanced? Thanks.
