11.18@119.7
'87 Stock engine.
Heads and intake were never taken off (factory sealed)
PT 54 turbo running around 30 psi
Comp Cams v-springs
3" thdp
ATR crossover pipe
ATR dual exhaust
1 1/2 stretched stock loaction i/c
65lb injectors
Joe L chip with 26 degrees of timing
Turbo Blue gas (112 octane)
Hot wired Walbro pump
200 4r trans with non lockup 3300 stall converter
stock rearend
RJC plate
stock tb & upper plenum
stock intake
tuned with Direct Scan
28"x10.5" M/T ET Streets
'87 Stock engine.
Comp Cams v-springs
3" thdp
ATR crossover pipe
ATR dual exhaust
65lb injectors
stock rearend
RJC plate
stock intake
