GNBRETT
Pelennor Fields
- Feb 8, 2004
How much does the car weigh?
SignUp Now!How much does the car weigh?
I'm thinking maybe the boost gauge is a little/allot off.![]()
You see, we just took a page out your own book "I just make it look easy"![]()
Don't believe it? Come test it out? I'll put some $$$ on it to make it worth our while?
I think you don't believe it because your car isint as fast as his, with you on twice the boost AND alky huh?![]()
Dominic built the car... and what numbers do u think the car should of produced at 17lb.????Who bulit the car? Im with rick I think the boost is off...... the turbo cant produce enough air at that boost level for those times IMO even with a 4 bolt housing I just dont see it...
Dominic built the car... and would numbers do u think the should of produced at 17lb.????
117-118.... thats who I taught built it but I wasent sure.
117-118??? what does that mean
Thats Alot of money for 11's turn the boost up.
It can if he revs to 6400-6500. 5600 seems a little off the mark for those numbers though. The only limiting factor would be the cam. With a solid cam and a little more rpm id bet he could go over 130mph while under 20psi. Maybe he will post a data log
