11.53 @ 118.47 on 23psi 93/alky
cuda6pak
Finally got my new combo out for a run. Was only able to make one pass for the day, I got some knock up top and had to let off and brake right before the finish, still figuring out the issue. This was with the combo below on 23psi, single M15 alkycontrol, 10.6 target AFR. Full weight GN with Centerline drag wheels, aluminum driveshaft, sub, amp, and 120pc Crafstman tool box in the trunk!
60' - 1.94
1/8th - 7.459 @ 96.64
1/4 - 11.536@118.47
The horrible 60' and 11.53 gives me hopes that this thing should run much better with a full pass and good launch! Very happy with the initial results. Just gotta clean up the tune and get the launch down. I was on ET streets for this run and have previously gone 1.62 60' on stock GN rims and Nittos.
Like you said 60 needs some work...Looks like in the vid you could do a longer burn out to get the tires hotter...How much boost you leaving the line with??? My KR at the top of the track is boost spike.. Good job!!
