- Dec 15, 2002
JSTA6, would you guestimate that this set up is around $550 new?
SignUp Now!DR.BOOSTER said:JSTA6, would you guestimate that this set up is around $550 new?
onefastcar said:check this thred out interesting talk.
http://www.gnttype.org/forums/showthread.php?t=3903
The diameter is misleading. If you look at the stock brakes, the actual center of the pad is only about 4 and 1/2 inches out from the center of the rotor, so the "braking radius" is 4 and 1/2. If the S10 brakes move that out to 4 and 3/4, that's about a six percent increase. The area, which is the heat disapating part, increases by about 10 percent. Plus, the better calipers. So it looks good to me, for those who don't want to change spindles and suspension parts, and wheels. Especially for vacuum brakes, where you could match the master cylinder to the calipers, which would probably work even better.Sounds like a lot of work IMO for an extra 1/2 inch in diameter
Ormand said:So it looks good to me, for those who don't want to change spindles and suspension parts, and wheels. Especially for vacuum brakes, where you could match the master cylinder to the calipers, which would probably work even better.
Kinetic Dan said:So, from reading this thread, the S10 spindle/calipers offered in this eBay auction would give me everything I need, and line adaptors?
and if I wanted to run 2" drop spindles, I'd have to use S10 ones, right?
**EDIT: The calipers on the auction look a lot smaller than those in your conversion, even though this is an 03 S10?**
http://cgi.ebay.com/ebaymotors/SPIN...33564QQitemZ8025827433QQrdZ1QQsspagenameZWDVW
TURBOTWIN2 said:That's single piston calipers. Came on the pickups. You want dual piston set up off of the Blazer models. 98 up, I believe.
Phatman said:Maybe I missed it, but has anyone tried this mod with a vaccum brake setup or just the hydroboost?
