SignUp Now!head for a junkyard, and if you can't find a 76 or 77 Monte, then get the backing plate (with all the parts still attached) from a Caprice cop car, taxi, or station wagon- look for the bigger 5X5 wheel bolt pattern.
buy new shoes, cylinders, and spring kit for a Caprice with big brakes and get some new Monte drums and you are good to go.
There aint enough meat on the flange to do it safely. You'll just end up FUBAR'n a perfectly good axle housing.
Used is the only way you'll find 11" plates.
I HAVE A BETTER IDEA ,,SWING BY MY GARAGE AND INSTALL A SET:biggrin:
