1" bore, fittings point the right way, has a low fluid sensor, 4 wheel disc application.
Correct, the only duty my *combo valve*, performs, is that of a junction block.
BTW, I also spent a fair amount of time, verifiing, neither end prematurely locked-up, and wound up going to a larger front tire to achieve the final balance.
