120 AMP AC Delco alternator with PT&E adjustable voltage reg
ULUZ2A6
Low on traction
Alternator w/ PT&E Adjustable Voltage Regulator bought new about a year and a half ago. It is 120 AMP. I must be honest, I am not happy with it's performance on my application. I have an electric water pump that is in the way of my belt and was forced to under-drive the alternator pulley. It doesn't respond well at idle and low RPMs. I went with the 140 AMP Impala SS one and solved my problems.
If you are not under-driving it it will work great.
I have over $225.00 in it with regulator.
Hows $100.00 shipped?
NP Chip..sometimes the forum doesn't notify me of new PMs either..
was the problem at low rpm and idle because of the elec water pump? and will it work fine on a stock setup? if so im interested
sold
the problem was that i had to under drive it to avoid my water pump. not designed for that.
