AN/GSC-52
- Dec 6, 2009
I'm pulling the pump to install the PTK pump tube kit. Would it benefit to change to a 13 vane pump at the same time?
Add says
200-4R high performance / high volume pump rotor kits. Turn your seven or ten vane pump into a thirteen vane pump. This kit will eliminate irregular pump pressure above 5,000 RPM. Transmission must be removed to install this kit. (When using a 13 vane pump don't raise the motor speed above idle until the transmission is full of fluid, doing so may break the pump rotor.)
Add says
