$1500...how fast?
ANDYS87 said:
275/50/R15's will fit on factory rims....and without spacers! They work on my car atleast. VERY BIG improvement than the whimpy factory rubber. Do the right rear airbag too!
They fit OK though most people have some rubbing issues and they wear funny, are prone to cupping up in the center if you run too low a pressure and won't hook as good as the narrower 275/60 unless the track is so sticky your shoes come off when you walk on it.
Also the Nitto 275/50's are TOO SHORT (only 25.7" new) and a stock long block TR will run out of RPM in the 1/4.
