SignUp Now!Just to clarify, you bought them non flow matched. They are cheaper that way.
Eric
He states on his website flowmatched within 1%.
You might want to check what you actually ordered. If you ordered 6 individual injectors, then they're not matched. You would have to select the 6 pack for the flow matching.
If I'm wrong, then you got a good deal!
Regards,
Eric
I was understanding that these are flow matched within 1%. I will recheck these.
I bought six at a time -I did not buy singles.
awesome! I just checked and didnt see them yet. I will check in a few more daysI ordered a few flow matched sets of 120's a couple days ago. I'll put them into the webstore as soon as I receive them. They'll be about $390 a set.
FLOW-MATCHED 1% INJECTORS ARE SOLD IN PACKS VIA THE 'BUY IN' DROP-DOWN MENU ABOVE.
INJECTORS SOLD AS EACH ARE NOT FLOW-MATCHED (LISTED FACTORY TOLERANCE APPLIES)
I guess the $60 is for someones labor charge to test each one out on whatever machine they use. I guess its worth it?My bad. I just had to ammend my order to make them flowmatched-about $60. More.
This is also why it is good to tune on the rich side to compensate for lean injectors/cylinders. Peak power window on e85 is pretty large compared to gas. I like the 10.3x range personally...(gas scale) My 83's were tested and within 6% of each other... Not sure on the 120's I just bought.
Very true, but they weren't 6% less than what they claimed to flow. There was a max of 6% difference on the wost of them. Which is typical. In my case it was because 2 of them flowed more than their rating.
