160 thermostat
I have a 160 if anyone needs one just pay the shipping
Autozone part # 3846 for the thermostat cost about $7-$8 and no trimming involved! Part has to be ordered.
What's the hole for?
I'm not 100% positive, but I think that the hole allows a little water to go through while close. This keeps the temp from really spiking up before it decides to open thus allowing a more stable and uniform temp during warm up.
Just wondering because my 160 took a shit & I replaced with a 180 but didnt drill & it works perfect, so much better & for some reason runs down the highway between 162-165. Gonna pull it & drill it just to be safe since it is highly recommended. Thanks for the info guys.
Drill a 1/8" to 3/16" bypass hole through the T'stat & mount the hole at the 12 o'clock position. Done!
Does the hole need to be in the actual thermostat or in the outer sheet metal area?
In the outer sheet metal even though it really isn't necessary. If you do drill a hole I wouldn't make it any bigger than 1/16"
I drill the smallest hole I can. Typically 1/16.
I also went back to 180 stats in both cars.
