Ive ran into the same issue. Motor is good at cruise and not in boost and screems when in boost but that 4" to 3 PSI zone rolling into it seems like a dead spot. I cant get my power valve system to work. At one point I bypassed the PECV since mine was bad. Its good under 8" but real lean anything less until the secondaries open. My power valve isnt releasing even with a good PECV.
I never thought that timing was causing the mid throttle dead spot. Ive got an NA v6 distributor and MSD BTM with no ESC.
Well I was wrong, not about the carb hat but about the cause of the ESC system triggering early.
it was not the timing that caused the knocking and got the ESC to trigger and pull advance.
It was my plug gap. I had been gapped at .055". When I regapped to .032" the timing drop issue disappeared.
I will do some driving tests and report back.
Here is my timing thread: I am now at 36 total without Vacuum
http://www.turbobuick.com/forums/threads/timing-and-boost-on-a-carbed-turbo6.411746/
ALSO
I had been having some low oil pressure lights when the car got good and hot - typical stock buick system in my experience. Reminds me of my SBB350.
I went to 20W50 oil to tighten things up a little and
I added a spacer to the regulator spring to preload it a little. (Since I seem to have lost my spare red "60lb" regulator spring.)
Well somehow I lost the pump prime - and after trying a host of things to prime it again, I had to take the pump apart and pack it with vaseline to get it to prime.
I did change the pump shim from .008" to .005" to try to tighten things up a little too.
It was a pain - more than it should have been - but the effort was worth it. No more oil light when hot.
