SignUp Now!If you're going to try and weld cast iron you need some nickle rods for an arc welder. The part needs to be brought to a consistent cherry red before welding and then put back in to heat after welding. Then the temp needs to be brought down slowly so it won't crack again. One of the other guys may have 1 that they're willing to get rid of so I'd try that route.![]()
If this is an even fire engine do NOT put the odd fire balancer on it. The balance is different between the 2 and it will cause damage to the engine.
