1983 Buick Regal Limited | Stolen
Optional 4.1L 4BBL V6 w/TH350
Georgia / Fayetteville Car
78,000 miles
Maintenance Performed Within Last 3,000 Miles
Wheels & Brakes
  • Brake Fluid change with DOT 4
  • New front Rotors, Pads, Bearings and Seals
  • New tires
Engine
  • Coolant changed
  • New Radiator (Lifetime Guarantee)
  • New Water Pump
  • New Coolant Hoses; Upper, Lower and By-Pass
  • New Spark Plugs
  • Compression Test (Excellent)
Transmission
  • Transmission Fluid and Filter changed (NOT flushed)
  • Differential Oil changed (80W-90)
Miscellaneous
  • New Battery & Starter
Pictures Link : http://s677.photobucket.com/user/gstoykewich1/slideshow/1983 Buick Regal
Attached file is a copy of the original spec sheet.
$4,800
  • 1983 Buick Broadcast Sheet.pdf
Thank you, I've only ever seen a Grey/Black Limited. Never the two tone blue with matching interior. An LS1 will fit with room to spare in there!
There is a very nicely optioned blue D84 Limited that needs this car as a donor car. If they would have popped up together for sale I would have scooped them both, logistics of getting them back to Western Canada be damned. GLWS.
