1984 Trunk Lid RPO codes
papabear
Does anyone have a list of the RPO codes for the 1984 T-type's? I looked on gnttype.org and it only goes back to 1985. I remember seeing someone post a link to the 84's codes but cannot find it now. Any help is greatly appreciated.
John..
A lot of the 85 codes still apply, but here is a list of 84 codes that somebody posted a while back:
>AQ9 RECL FRNT BUCKET SEATS
>AU3 PDL
>A01 TINT WINDOW UPPER
>A31 PW
>A90 PWR TRUNK
>BC3 DELUX INST ORNIMENTATION
>BD1 ROCKER PNL DELETE
>BMD N/A
>BS1 INSULATION ACOUSTICAL PKG
>BV6 PAINTED LOCK CYL
>BV8 EXT HNDL & LOCK CYL
>BW3 EXT WINDOW TRIM PAINTED
>BX1 EXT FRONT END XTRA EMBLEMS
>BX5 DRIP RAIL PAINTED
>BY4 GN NAMEPLATE DASH
>B19 INT ORNI CUSTOM
>B24 BLK EXT SIDE WIND REVEALS
>B34 CARPETED FRNT FLOORMATS
>B35 CARPETED REAR FLOORMATS
>B48 TRUNK KIT
>B71 PAINTED WHL MLDG
>B72 PAINTED EXT MLDG
>B77 PAINTED EXT MLDG
>B79 ORNIMENT XTRA REAREND
>B81 MLDG BELTSIDE DELETE
>B89 EXT MLDG R-WINDOW REVEAL
>B93 DOOR EDGE GUARD
>CD4 INT WIPERS
>CF5 PWR ROOF GLASS
>C01 ORNIMENT EXT VAR. 2
>C18 ARM & BLADE WIPER
>C49 REAR DEFOG
>C68 ELECT CLIMATE CONTROL
>C95 INT DUAL READING LIGHTS
>D3D N/A (PROLLY SPEEDO GEARING)
>D55 CONSOLE
>D64 PASS LIGHTED VISOR
>D68 REMOTE PAINTED MIRRORS
>E5Z SPEEDO ADAPTER DELETE
>E7K N/A
>FE2 SUSP RIDE/HANDLING
>FFL FEDRAL FIREARMS LICENSE (N/A)
>GQ1 STD RATIO AXLE
>GU6 3.42
>G80 POSI
>G87 8.5" REAR
>K15 FUEL VAPOR RETURN
>K22 94 AMP ALT
>K34 ELECTONIC CRUISE
>LM9 TURBO V6
>MW9 TH200-4
>MX0 200-4 PKG PART OF TURBO PKG
>NA5 EMISSION SYS
>NB1 CLOSED LOOP EMISSIONS
>NK1 N/A
>NP5 LEATHER WHEEL
>N33 TILT WHEEL
>N89 ALUM TURBO WHEELS
>QYH 215-65-15 WOL
>TL6 BLK GRILLE
>TL8 EXT HOOD MLDG 3.8 SFI
>TT5 N/A
>T43 REAR SPOILER
>T47 TURBO HOOD
>T63 HEADLAMPS ON ALARM
>T83 HEADLAMPS DR SPECIAL
>T93 TAIL LAMPS SPECIAL
>UA1 N/A
>UQ1 PROVISIONS FOR STEREO
>US7 PWR PAINTED ANTENNA
>UU7 AM/FM CASS
>U52 DIG DASH
>U66 4 SPKRS
>VA2 STEEL RAD SUPPORT
>VD6 ALUM BMPR SUPPORTS FRNT
>VD7 ALUM BMPR SUPPORTS REAR
>VK3 FRNT LIC PLATE BRKT
>V73 N/A
>WA8 N/A
>WE2 GN PKG
>WG1 SALES PROCESSING FOR PWR DR SEAT
>W11 TTYPE PKG
>YR2 N/A BUT LEARS I THINK
>YS2 N/A
>YT9 N/A
>19L SECND EXT BLK LAMP
>19U PRIMARY EXT LAMP COLOR
>6YT N/A
>60H LT DRIFTWOOD INT
>60I MED COGNAC INT
>609 MED COGNAC SEAT BELTS
>7YU N/A
>8HP N/A
>9HP N/A
I have some of the ones that were listed as N/A's.
FFL: Flint, Michigan + Fisher body plant 1 BOC (Buick Olds Cadillac Plant)
TT5: Tungsten Halogen headlamps
UA1: Heavy duty battery
V73: US/ Canada (vehicle statement)
YT9: specified, division installed (Fisher) Reference to custom door + quarter buildup option code YT1
6YT: Front, driver side spring rate
8HP: LH rear spring rate
9HP: RH rear spring rate
Hope this helps out. I am also still missing descriptions of the following codes:
BMD, D3D, E7K, NK1, N90, T1Y, VO8, WA8, 6CU, 7CU, 7YT, 77E, 77I, 779, 9PZ.
