THIS IS NOT AN ORIGINAL UNTOUCHED VIRGIN, IT DOES HAVE THE ORIGINAL ENGINE NOT TRANS. ITS A HARD TOP CAR WITH DIGITAL DASH AND WORKING A/C,POWER WINDOWS AND LOCKS.
(Now that we have weeded out the collectors)
1986 GN, Working cold a/c, digital dash modified to read up to 199 mph,this car is completely streetable and can be driven anywhere.car has approx 42k miles before I replaced dash with upgraded dash.It has the original short block rebuilt approx 500 miles ago.has a custom grind roller cam with stud type 1.65 roller rockers,dbl roller chain,hi vol oil pump,Champion GN-1 alluminum heads,arp bolts,cometic head gaskets,allum champion "turbo" valve covers,custom external breather tank with braided line,champion ported intake manifold,70mm throttle body and dog house.83lb injectors,msd dis-4 ign, coil pack, msd wires,Precision 71MM Turbo Brand new,atr stainless headers with external delta gate installed under turbo, 3 1/2" T/H down pipe custom refabricated to fit atr headers with dump and electric cutout, atr 2 1/2 stainless exhaust,4 core allum radiator, cotton front mount intercooler,4" chrome big mouth cold air intake set up,alt voltage step up,engine strap,ptc 9 1/2 in 3,000 stall torque converter, select turbo 400 trans manual valve body, reverse pattern,trans brake,ultra bell,b&m cooler,hurst quarter stick mounted custom in orig console with correct overlay kit,c/m drive shaft, eaton 30 spline posi unit,3.42 gears,moser axles,allum drums,t/a girdle cover, wolfe adj upper and lower rear arms, wolfe anti roll bar, bilstein rear shocks hal qa-1 adj fronts,(also have bilstein fronts),aeromotive 1000 hp fuel system,external pump with braided lines and fitting in bottom of tank,accel gen 7 dfi fuel management system, autometer carbon fiber oil,water,boost,volts,(2 in pillar and 2 in console)5" carbon fiber monster tach with shift light,hurst line lock, fiberglass front bumper and hood, weld allumistar rims front and rear m/t drag radials on rear. turbo hsg,turbo shield,intercooler pipes all polished.all work was done and car was tuned by Turbo People of New York approx 500 miles ago. car has never been raced but ive been told it is set up to easily go bottom 10's. I have several cars and this one sits mostly and now i lost my garage next month and its gonna kill me if this car isnt garaged. E-Mail for pics and if serious about coming to see car. asking $18,000. located in New York 20 mins from GW or TZ bridges.Thanks
