scot w.
GNSperformance.com
- Feb 19, 2005
More progress...
SignUp Now!hope you plan on cleaning that oil out of turbo outlet and putting in bypass filter. that is a very nice motor and you got luckyProgress pic's up to today...
Already ahead of ya!hope you plan on cleaning that oil out of turbo outlet and putting in bypass filter. that is a very nice motor and you got lucky
poston enterprises or jay's gn i think 38 bucks for a polished oneAlready ahead of ya!That was cleaned out and the orriginal breather comming from the pass valve cover has been removed and a push in breather will be installed. The breather inlet into the turbo has also been capped off as well. We may even go with a new inlet bell if we can find one.
Scot W,
Yes! Made by (Micro Tech).Scot!! Is that an "hour glass" MAF I see??? Gotta get rid of that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
" I happen to know who has a brand new A/C delco stock MAF still in the box!!"![]()
Scot W.
LOL I'm cracking up right now!! LOLDon't even think about it.![]()
I already mentioned to him he the minute the car got here that he needs to get a Orriginal stock MAF but right now he's on a budget, I'm sure in the near future he will get one.
I have one here but the only problem with it is at WOT it reads Less than 255 grams of air per second. Other than that it worked fine.
Scot W.
Trust me, It was with a TE-44 & a TE45a at around 18-20lbs of boost and SHOULD have been maxed out at 255gms per sec from either turbo.that maf maybe ok what boost did that reading show it may not max out at 14 and under
yes its bad then. have you tried cleaning it with maf cleaner.Trust me, It was with a TE-44 & a TE45a at around 18-20lbs of boost and SHOULD have been maxed out at 255gms per sec from either turbo.
Switched with a known good one at the time and WALA problem fixed!
Scot W.
You should know by now! It goes on top of the scanmaster!!! :biggrin:looks good give me call,where does the wing nut go ?
....Snip... I would not remove the heads at all! ....
