1987 T-Type 4-Sale
Bluvette
1987 Blue T-Type
Diamond Pistons, Rings, Pins
Roller Cam Kit
HV Oil Pump & Front Cover
340 Pump
HD Main Bearings
HD Rod Bearings
ARP Main Studs
ARP Head Studs
ARP Rod Bolts
Line Bore & Hone Mains
Complete Valve Job
Big Stuff With Laptop
3 Bar MAP
84 LB Injectors
T63 Turbo
70MM Throttle Body
Fuel Pressure Regulator
Built Transmission
3500 Stall Convertor
Front Mount Intercooler
Aluminum Radiator
Moser 9" Rear End With Wilwood Brakes 3.73 Gear
Hawk Pads All Around
3.5 Aluminum Driveshaft With1350 U - Joints
Line Lock (Roll Control)
BMR Upper And Lower Control Arms
Weld Rims
MT ET Drags and Skinnies
MT ET Street
Plus Factory Rims With Tires On Car Now
Fuel Pressure Gauge
Oil Pressure Gauge
Coolant Temp. Gauge
Boost Gauge
4 More Info Please Contact Below
ASKING $17,000 FIRM CONTACT POWERHOUSE PERFORMANCE,INC. 708-342-0043 OR EMAIL PHPINC@NETZERO.NET
Any more detailed pics you could post? Interior, engine bay, undercarriage, etc.
More Pics. As soon as I have a lift open I will get some pics from under the car.
How many miles on the body and the motor? Whats the cars e.t.s and more pics of course
The body and drivetrain have 76,000 miles. The motor has 1500 miles. Cars still needs to be Dynoed. Also I forgot to mention there are Lakewood shocks all around and an airbag on the rear passenger side. A/C does work. Here are some more pics.
Here are some photo's from under the car. Also someone asked if the car had cruise control, and it does. Car needs to go before winter make an offer.
Here are a few more.
What kind of crank, rods, any billet main caps? Stock heads? What Gen BS3 is in the car.....
just throwing this out there, but im looking to get a beefy rear end setup for my car... i got a good 8.5 with some goodies, and was wondering if we can work some sort of trade....
LMK
-Jeff
