1987GN rear end check
junkin
Have plans to buy a 1987 posi from a guy that I don't know this weekend. Need to know what to look for as far the condition with it in a truck bed. What tells me it's a posi, how much moment in the yoke and etc. Any help will be appreciated.
On the front of the passanger side axle tube it should be stamped "3TP". That is the code for an 87' 8.5" posi. Pull the cover to make sure it has a posi carrier in it.
There's more than one code for posi/gear ratios on these rear ends. It could be a 3.73 out of a 442 or a 3.42 posi out of a 84 hot air. Here's a list out of the parts books.Some part of these 3 dogits codes will be stamped on the tube. The stars indicate posi.
3.42
GTE
GTP*
6TJ
8TJ
8TP*
2TJ
2TP*
3TP*
3TJ
3.73
6TF
8TF*
8TH*
8TF
9TR*
9TF
2TG
2TR*
3TG
3TR*
It's best to pull the cover and double check it anyway.
