1997 Blazer Radio Removal
84GNTTYPE
Senior Member
I want to remove the stock radio on an '97 Blazer so I replace it, but I'm not quite sure how to get it out without wrecking anything. I'd appreciate it if someone could tell me how to do this or where I can find out.
Thanks!
I have a 96 s10 and to remove the radio first you have to remove the dash bezel then you will see the screws holding the radio.:)
there are a total of 4 screws holding it. Two of them are on each side of the steering column the other pair are by the dash cluster
The rest is held by clips and pulls out.
Drawings not too good
Top of dashboard
| Dash cluster
