Hey guys,
Ive been anxiously waiting to make a few passes doen the 1320. Tonight I did. My setup is in my sig. I am happy that this project is showing results!! Well anyways, I averaged in the mid 13's all night w/ a best of:
60' 2.1932
330 5.7331
1/8 et 8.5931
1/8mph 86.22
1/4 et 13.1771
1/4mph 106.87
My 60' is crappy but am not building any boost off the footbrake and will only stall to 24-2500rpm. I am running the TT 93 Street Chip w/ zero adjustments. It is definatly running on the good side(740+ O2's) but During this best run, I saw 15.9 degrees of knock retard and it stayed steady toward the big end. I was running 16 lbs of boost.
The bL is usually around 140 @ wot, air temp was around 120 @ air filter(is this alot?)I didnt catch every reading on the scanmaster, I was too scared to blow or mess anything up.
On the way home, I did a little 1/4 throttle pull in 3rd gear, 16lbs of boost and 3.3 degrees of KR.
Long story short, is there anything I can do to get rid of the knock retard? I do have a worn passenger side engine mount, and a 3" downpipe that is around 1/4" away from the framerail. Thanks for looking!!!
Chris
EDIT: btw, this is running on Shell 93 V-power.
60' 2.1932
330 5.7331
1/8 et 8.5931
1/8mph 86.22
1/4 et 13.1771
1/4mph 106.87
Chris
