- Aug 1, 2003
in an earlier post he said his 02 was 700ish at idle. shouldnt they bounce or cycle between 0-800-0 when not in throttle. During a WOT blast or at least part throttle doesnt the chip tell the ecm to let the 02 dictate fueling in open loop or is it closed loop i dont remember as i am new at this stuff still. If the scanmaster reads a constant 700ish at idle then i beleive that the 02 is bad.
tt chips are openloop idle all the time so no the o2s wont flip flop rich lean at idle , crosscounts will hold steady as will the O2 MV except for a breif moment every so often when the chip comes out of open loop to take a peek and make a small adjustment if nescessary (watch the little blinking dot on the SM display for when it flips from open to closed loop then back again )
and yes you need a shroud , with the shroud you get ambeint air to cool the intake charge, without it the radiator is making your intercooler into a interheater and thats not good for trying to make boost without detonation
