Underboost
Mr. Dull
- Oct 4, 2005
I have been running the turbo tweak chips for a while now and have noticed when I install them I go out on a good street and make a pass if it knocks I add some fuel, I always set the timing to 25-26 @ 26-28 psi. If I end up going into the 140's on the chip fuel adjustment I'll go up on the regulator and come back down on the chip. It seams to work out well for me 02's are 790-800
1600 EGT's. This is with Alky & Pump. Race gas I tune a less on the fuel.
Also cabech984 I would put you're stock TB & Plenum back on your not ready for that big 70mm yet. It could be hurting you. I ran 10.90's with the stock set up.
Hope this helps
