2-1/2 rear coilover springs
chasmat2316
What pound & height rear coil over springs are guys using in a full weight GN? I would like to lower the car about an inch or two from the factory ride height
12-130 to 12-150 depending on how stiff you want it
using the wolfe racecraft adjustable spring perch to dial in the height
MOOG 6377 or 5413 will do what you want. The 6377 (141 lbs/in) are heavier than stock but not much and the 5413 (167 lbs/in) are stiffer and will give you a rougher ride. There's a whole thread about different springs on here and it's several pages long if you feel like doing a search.;)
