2-3 flare, I have pressure test results
wh1-Denver
I just did a pressure test on my tranny.
TV connected at idle
P__109
R__110
N__108
OD_106
D__106
2__108
1__96
TV disconnected at idle
P__102
R__110
N__102
OD_98
D__98
2__102
1__98
1500 RPM TV full
P__194
R__184
N__192
OD_175
D__184
2__190
1__175
I have PTS shift kit, billet internals, and PRV.
I have developed a flare in 2-3 shift.
The pressure @WOT is at 150 and it drops to 130 for the 1-2 shift and drops to 110 for the 2-3 shift. the drop only last as long as the shifts.
The tranny has been rebuilt twice (by two different guys since I moved) in the past two years and I am beginning to get really get pissed off with all the f-ing money I have dropped into it and still problems. I am letting the second trans rebuild guy have one more shot at it. He wanted me to do the pressure test to help him diagnose it.
Comments for what might be wrong are appreciated.
Is that the press. all the time 150 @ WOT? That's low sucking @ filter or weak pump slide spring. Mine had a similar press. prob. put in a stonger slide spring & I think that's what fixed it.
No trans. guru just trying to learn & help.:cool:
Jim
your int/reverse boost circuit is no functional.maybe the oil signal pipe is missing on the valve body,or the pump is misassembled.
Looks like pump problem.
BTW.. how did ya like that guage :)
That thing is mammoth.:eek: It worked way better than that cheapy from NAPA I used last time.:rolleyes:
