Will TA Performance set them up the way you order them as well?
Also, can you get an 8 bolt head with stud mount rockers?
Do a search on Champion and TA heads... draw your own conclusions. :wink:
I did just that and decided to buy the TA heads. I'm glad I did.
They will set them up exactly the way you want them. You will also get a build sheet with the heads. Each head comes in a sealed bag, with every coolant port taped-off to prevent any possibly loose debris from falling out of the passages and contaminating the rest of the head.
I can't speak for Champion, but TA's customer service is 2nd to none. Mike T is the owner at TA Performance and he's fantastic to deal with.
Go to the website and download the catalog to see the details about the heads... I think the catalog goes into more detail than the website gives.
I've spent alot of time on the phone with Mike at TA... and learned a few things about those heads that are not advertised... like the insanely overbuilt nature of the head, the huge deck thickness and the amount of material over/around the combustion chamber.
I don't think you will EVER see or hear about a cracked TA head. Champion on the other hand... different story. (do a search)
All TA's heads are 14-bolt design. They bolt right on an 8-bolt block. Just ignore the extra holes.
I bought the entire top-end of my motor from TA Performance. I don't think you will find a better cylinder head.
Also, if I'm not mistaken... a TA head will flow better right out of the box, unported... than a stock ported iron will flow.
Here's some eye candy for you.
Build sheet with every head:
