2 motors for sale.....109 & stage motor..
dentmasters01
109 motor with atr big cam, just freshened up new bearings ect.... $2500.00
016 casting staged motor with new steel crank, 0 miles since installed...$4000.00
any questions send to 4dgg@comcast.net
or call me at 615-456-5646
Are you sure it is a stage 2 and not a stage 1, I am just going off the casting number 016, pm me your best price and a list of the specs and parts that come with it, is it a complete short or long block, oil system, heads, cam ect...
Buick V6 Engine Block Guide
Check this link out
Whats the location of the oil pickup tube? between the two front mains (stage2) or between the 2nd + 3rd?(stage1) ---What crank is in the stage motor?
Check this link out
The 016 casting was made in a stage I and II. My block (unlike the one in the picture) has 4 bolt steel splayed mains and the oil pick up is in the front beside the first cap.
Stage II 4.1 block 4.030 bore.
016 casting
O ringed cylinders
2 sleeves
Stock rods polished, shot peened and mag checked
Forged pistions
childs-albert rings
edelbrock double roller chain
comp cam 212-212
ARP main studs and rod bolts
Block has been filled for added strength
Comes with new BHJ balancer
Just spent 2k at the machine shop for new eagle steel crank, and mancine work.
is the 109 short block a stock rotating assembly or any aftermarket parts ??
This was a fresh rebuild with about 5k miles on it. All factory parts. It showed signs of low oil pressure due to the previous builder not clearancing the bearings right, so we pulled it out and my builder went through the bottom end and made it right.
NEW PRICE !!
109==== $2300.00
SII==== $3800.00
I'm dropping these 100 dollars at a time until they sell !!!!!!
BETTER JUMP ON IT !!!
What are the specs on the ATR big cam and is it a roller or a Flat tapped???
Fordge or cast pistons??
Studds or bolts on the mains??
Maybe interested :)
Maybe interested :)
Don't know the specs on the cam, but its in the atr catalog if you can find an old copy. I may have one. Its the biggest flat tappet cam before going to a roller.
Forged 30 over
All ARP bolts in the bottom, studs on the mains.
