2 sets of 8445 heads 1 ported 1 stock ferrea valves!!
87chrisss
BLUBYU
i have a set of bare 8445 heads with lots of hours on port work cleaned by local machine shop have not yet been resurfaced.. not sure if i was going to o-ring them or not? time to sell! will include ferrea intake valves new in the box with some spare stock pushrods i have... you would need springs and exh valves to w.e setup you would want, also the ferrea int valves are oversized so you would need to bore the intake valve seat to accomodate the ferrea valves unless you want to use your own valve size?... the second set i have are spare 8445 heads they have very minimal bowl work with stock valves i bought of gessler a while back these have new springs etc.. i think stock valves? they have gm stamped on the intake valve shipping is not included in price
Bare Ported heads $375
Bare Ported heads with ferrea intake valves $425
Spare heads ready to bolt on new springs- $425
Just found the exh valves i have everything for the heads or i can sell the valves separately i knew i had them somewhere !!
