Just need some input on this situation. Its a very long story but I have a built transmission from said builder from 10 years ago that wasnt right when I got it. So it has my originaly BRF valve body installed and has worked decent for 10 years (cant be more than 6 or 8K miles tops) and some track time. Ill just get into what happened.
I drove the car to work yesterday and rolling about 35mph I squeezed on it and it kicked down to 2nd and built boost and ripped hard as it usually does (a little laggy with the old school orange crush 3000 converter). Didnt think anything of it pulled into work shut it off. Went to go home and it was winding up in 1st gear and wouldnt shift until 4 grand. Hmmmm.
I get it home (wont go into OD) and part it. Check TV adjustment and it was where it always has been. Fast forward to this morning. Drain the pan, drop the pan. I have silver metal by the governor area otherwise normal black clutchd dust and the magnet had some grey goo on it. I pulled the governor down and it had some small debris in it (metal) so I cleaned it up. I also made sure the spring was still there and it was. While the pan was down I adjusted the TV cable with a friend WOTing the car and me underneath the car making sure it was fully depressing the valve. And it was. So I put it back together threw fluid it and hooked up the pressure gauge. Here is what I had.
COLD startup:
P - 105
R - 150-180 bouncing
OD - 100
D - 100
2 - 180-210 bouncing
1 - 180-210 bouncing
WOT - 180-210 bouncing
HOT:
P - 100
R - 160
OD - 105
D - 100
2 - 165
1 - 150
WOT - 180
So I drove it around the block. Late upshift 1-2 at like 4 grand. Pulled it back into manual 2nd after this to make sure I had 2nd gear and I did (tough to tell but I think it was in 2nd and didnt downshift but it did clunk when I did that). Held manual 2nd and manually shifted to 3rd and it engaged. Came up to the stop light and the car leaves in 2nd gear. If I WOT it real quick it kicks into 1st. Or if I manually pull it into 1st it goes into 1st. But it wont do it on its own.
At this point I was getting a little angry so I went out on the parkway and left it in manual 2nd gear and went WOT. It is NOT slipping, pulled hard and let off and clicked 3rd, then tried OD no OD at 55mph. Came to a stop its in 2nd again. WOT it real quick kicks to 1st and late upshift into 2nd then immediately to 3rd. Hrmmm.......... What do I have to lose now........... after this I decided to take it on the highway to see if I had OD. Got about a mile from the house and sitting at a stoplight and I am hearing some odd noises. Put it in Neutral and noise went away. Said screw it turned around to come home and smell trans fluid hot/warm. Not horrible but smelled it. Drove home through the neighborhood slow 1st gear was starting to surge a little. Its parked now................... WHATS BROKE? Besides my wallet? Thanks fellas. See you in Bowling Green in the Marauder.![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
COLD startup:
P - 105
OD - 100
D - 100
HOT:
P - 100
R - 160
OD - 105
D - 100
2 - 165
1 - 150
WOT - 180
