20" wheels on GN
NO5O
I saw pictures of a GN on 20" torq tII beautiful looking ride. Anybody no what combo will work without rubbing or lift?? It looks like he ran a 3.75 bs with 20x8s no rubbing. I would like to run a little wider rim in the back. 20x9.5 is this possible?? any help would be awesome.
20x8.5 will need 4.25 BS (add .5" w/ drop spindles).
20x10 will need 4.75" BS
245/35-20 fronts
275 or 285/30-20 rears
I ordered my 20" yesterday, I will be running adapters and spacers to get mine where I need it w/ my height. I'll post pics once completed.
what wheels did you get?? Im looking at keeping the stock ride heigth . Will what you listed work with out spacers or rubbing? thanks again also the wheels im looking at are 20x8 and 20x9.5
The wheels I ordered require spacers to get the backspacing correct. I got Boss 338s. Stock height the BS I listed above will work fine w/o spacers using the tires I listed. Regarding 8" fronts and 9.5 rears, I'd do a 4" BS on front and a 4.25 on the 9.5". Someone w/ this set up will chime in, even on 18" it'll be the same BS needs.cYou will discover the car looks lifted when you see that low profile tire next to a wheel well gap....even if its 1.5" gap next to a 1.5" tall tire sidewall, it'll look like the car is taller..... IMO
I don't know about the BS, but I have 19's on my car. 19x8F, 19x10R picx are on my cardomain site.
r u using any spacers? bs not sure? I have to special order the wheels and would hate for them not to fit. thanks
