2000 Camaro ss 23,000 miles built ls2 looks and runs factory
smoke20
Year: 2000
Make: Chevrolet
Model: Camaro
Price: $16000
Mileage: 23300
Private or Dealer Listing: Private Listing
Location (State): WI
Color: Black
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Up for sale is a 2000 Camaro SS. has 23,000 miles. 2 Owner clean car fax and title. Have window sticker,Birth certifcate from GM, all parts invoices and manuals, Owners manual. and MUCH MUCH MORE.
Cars has working A/C, Cruise control, Power windows and locks, ABS,Traction control. Factory Monsoon radio with 6 Disc changer. Not even ta mark on a pannel, Leather seats. HARD TOP ROOF
Email culater@charter.net or call 262-388-3331 for more info
Engine LS2 storked to a 402 ALL NEW PARTS LESS THAN 1000 miles on build
New GM LS2 block
Eagle Forged crank
Eagle H Beem rods woth L19 bolts
JE Forged Nitrous Pistons 10.5 compression
AFR 225 Mongoose CNC ported heads Part#1630
Ls2 intake
FlowTech cam .646 lift .242 intake .246 @.050 dur
Comp Cams rockers (with Poly Locks)
Chrome Moly push rods
SLP oil pump
SLP timing chain
ARP head studs
All ARP bolts threw out engine
SRP radiator (BIGGER than stock)
Transmission
4l60E Built by Automatic Transmission design in Germantown Wisconsin
All Billet and harden parts to handle 900 HP
Yank super stock 4000 race converter
Derale transmission cooler (plumed with 6an line and fittings)
Rear end
Strange 12 bolt 33 spline axles
Has traction control and ABS on it
Ta performance rear end cover with girdle
3.5 inch aluminum driveshaft
Exhaust
SLP 1 3/4 coated headers
Speed inc TRUE dual exhaust with X pipe
Borla mufflers
Susp
BMR TQ arm Reloaction crossmember
Slp adjustabe TQ arm
Hotchkis swaybars, Trailing arms, Panhard bars.
Brakes
Bear 13 inch 2 peice front rotors and calipers
Bear 12 inch rotors rear and calipers
All stainless steel brake hoses and dot 4 fluid
Misc
Power master starter, msd coils,Racetronix fuel pump, green top injectors.Line lock im sure im missing a ton just ask and I will help answer any questions
