2004R CZ street/strip trans perfect for a daily driver
brian
Senior Member
Trans is a CZ model out of a Monte SS, with the correct governor and valvebody. The governor spring has been pinned to bring the WOT shift rpm down to about 5200.
This unit has a hardened and welded drum, and a hardened input shaft.
Has new switches, 500 & 300 boost valves, ring kit, PTS billet servo, a baffle for fluid control, and has a built in drainplug as well.
Shifts will be crisp and quick with this unit. Easy mid/low 11 second capable trans, but would be perfect for a daily driver.
This trans could be used with any fresh restalled stock converter, as this one will not shift quite as firm as my more "race" type builds..
No transbrake on this one.
Price is $1700 + $150 shipping.
No core needed in return, and this is ready to ship!
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
You know I want it but I'm not ready to make that move yet. Hope you have one around later this fall. :frown:
I will do $1650 shipped to make this one go!:eek:
I need the space...
Brian
