2004R non lock up trans street/strip
brian
Senior Member
The trans is fresh, with all of the usual high performance upgrades.
10 vane pump, ring kit, .550 & .400 boost valves, Alto cluthes and wide red band, extra cluthes throughout, and our shift kit. This trans is a CZ model with a "Case Stretcher" servo, Art Carr non lock up valve, and a "stage right" style trans brake. (manual) The input shaft and drum are hardened, and it is set up for a 3.42 gear. This will be a very solid, firm shifting, reliable 10 second trans with ease.
This trans will shift at 54-5500 at WOT, so it is perfect for a ported heads and cam car.
Price is $1450 outright, no core needed. Although I will accept a core in return. And will ship for an additional $150-$200.
Feedback can be viewed in the "feedback" section.
Thank you, Brian Hofer hipsibri@cs.com
I also have a lock up trans to sell. Built the same.
Thanks, Brian
Will it work in a tta if so I will take the lockup one. It also has the tbrake in it right?
It will work in a TTA. A t-brake is also in there.
You will need to change your governor gear (or entire gov), and speedo bullet assembly. But that is a 15 minute job. :-)
Please shoot me an email, and I will give you contact info. I am about ready to hit it for the night. You can send me mail, and I will contact you tomorrow if you like.
Thanks, Brian hipsibri@cs.com
The lock up unit is sold.
Anyone need a great non lock up trans, this is it!
Thanks, Brian
Both trannies are sold.
Thanks to all who looked and inquired! :-)
Brian
