2004r problems
TurboTdr3.8
If the governor cover gasket is broken what symptoms will be in shifting ?
Nothing if I recall right
If it has a leak on the governor circuit it will have a late or no shift.
Even the base gasket that just holds the gear?
Governor pressure is fed through the case to the cover and the gasket is critical to sealing that area.
That's what I was getting at. Thanks
